- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
cant rename devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
when i click on any devices and edit it, i change the name and hit apply. when it refreshes the screen, the object still stays the same as what it was before. sometimes if i goto a different tab and come back and change it, it will work, but not that often.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: cant rename devices
after i login to the router via a direct wire. i goto attached devices and i select the device and change the name and hit apply. it comes back with the same name it was before. i even clicked on 'access control' and it gives a list of devices attached. i do the same thing here and the same results. i've rebooted. i have no FW upgrade. it seems a hit and miss but most of the time, it doesnt work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi jdt_69,
Try using a different web browser and see if that works. If not, factory reset the device and reconfigure it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Experiencing the same issue on the R8000P. Sometimes renaming works sometimes it doesn't. Your fix of adding to the existing name and renaming a second time did not work for me.
Logging in everyday for a week since I got the router has allowed me to change most of the names thus far through a persistent hit or miss approach, but it would be nice to understand why.
- Mark as New
- Bookmark
- Subscribe
- Permalink
---Case850 said "As I said before the correct and permanent way to change the name of a device is to do it on the device."---
And the router witl almost immediately reconized it if name change is done this way.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Despite having names of "Christopher's Echo", "Christopher's Second Echo", "Echo Dot", and "Christopher's Fire TV Stick", the broadcast IDs were all different variations of amazonXXXX. Perhaps I'm just missing another spot where I can rename it on the device, but I also can't figure out how to rename my older Vizio TV. No big deal really, just annoying.
- Mark as New
- Bookmark
- Subscribe
- Permalink
On the R7800 you could change the device name in the QoS window and in access control to a 'friendly name' it seems a few Nighthawk routers on current firmware are having isssues with this.
