Orbi WiFi 7 RBE973
Reply
changing ethernet connection in Nighthawk R7000P
beast_3
Initiate
My Nighthawk R7000P defaults the ethernet connection to the 5G network.
How do I switch to the non 5G network?  I can't see anyway to change it in routerlogin.net.
Thanks!
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 3
Accepted Solutions
antinode
Guru
Re: changing ethernet connection in Nighthawk R7000P
> My Nighthawk R7000P [...]
   Firmware version?  Connected to what?
> [...] defaults the ethernet connection to the 5G network.
   Which "the ethernet connection"?  What, exactly, does "the 5G
network" mean to you?  5GHz wireless?  There is no separate 5GHz
wireless network.
   What is the actual problem which you are trying to solve?  As
usual, you might get better advice if you described the actual problem
which you are trying to solve, rather than asking how to implement some
particular "solution" ("switch to the non 5G network") which may have
little or nothing to do with your actual problem.
Message 2 of 3
All Replies
antinode
Guru
wireless network.
Message 2 of 3
beast_3
Initiate
I found the problem wasn't with the router but a Windows app.
Thanks anyway!
Bob
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 825 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
