Reply
Highlighted
Follower
changing the IP address in a R6220
I have tried for hours to change the Router  ip address from 192.168.1.1 to 192.168.0.25  to use as an AP My mail router is 192.168.0.1  I thought after 40 years of this stuff I cound do it  NOPE  Help
Message 1 of 2
Highlighted
Guru
Re: changing the IP address in a R6220
> [...] R6220
   Firmware version?
> I have tried for hours [...]
   "tried" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
   Reading the documentation might have saved some time.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "Use the
Router as a Wireless Access Point".
   You should get your choice between "Get dynamically from existing
router" or "Enable fixed IP settings on this device (not recommended)".
   With "Get dynamically [...]", you could reserve a dynamic address for
the R6220-as-WAP.  With "Enable fixed [...]", you must specify suitable
static parameters.  (In which case, I'd recommend an address which is
not in the DHCP pool on the main router.)
> [...] I thought after 40 years of this stuff [...]
   Forty years of not reading the docs?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 152 views
  • 0 kudos
  • 2 in conversation
Announcements
