Reply
connecting to a BT youview box via IPTV
Robinso
Follower
I have tried to enable IPTV using the settings off the netgear site article id 29911 but every time I apply these settings I lose the internet connection. I know I must be doing something wrong or missing a setting so would be grateful for any pointers.
I am trying to connect to a BT youview box.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 2
JamesGL
Master
Re: connecting to a BT youview box via IPTV
Hi Robinso,
Double check the information from the BT youview if the settings are correct. When selecting ports, check only the port that you will use for your IPTV. Do not include other ports or the WiFi networks.
JamesGL
Community Team
Message 2 of 2
Discussion stats
  • 1 reply
  • 1615 views
  • 0 kudos
  • 2 in conversation
Announcements
