Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-01-26
02:39 AM
2021-01-26
02:39 AM
connection
ON a R6700v3
Unable to connect to UI of router
I did several resets
Check out the connection wifi to router is on
While ping the router the adress point correctly 192.168.1.1
I did try flushdns command
I did clear all caches
The router works but i can't get the UI with routerlogin.net or routerlogin.com
please could you give me some help?
thanks in advance
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-01-26
07:06 AM
2021-01-26
07:06 AM
Re: connection
Do you have it connected to a modem/gateway? and if so, which one?
Try disconnecting it from your modem/gateway, then factory reset the R7000 (push and hold reset for 7-15 seconds while its powered on), then try access it from the 192.168.1.1
Message 2 of 2
Announcements
