Orbi WiFi 7 RBE973
Reply
connectivity problem R7000
wabbak
I am in France and my internet connection sucks. But to at least not have any problems with wifi, I decided to buy a Nighthawk and not use my Orange modem, as the NH should have better antennas. The router is upstairs, downstaits I have 2 TP link extenders. Its an ancient house with walls that measure 50cm. Upstairs my mac and iPad have an okay connection. My Samsung phone will no longer connect!!! I see the different Ap's but it just won't connect. I go downstairs and its perfect. A few days ago it was no problem. But how is it possible that I see the Ap and it says it is strong but will not connect and only connects to much weaker extenders???? Please help, it is driving me crazy.
My connection on the Mac goes from 2 circles, or whatever you call them, to complete and that goes up and down. 5G will not connect. On another Mac, 5G will connect. How is this all possible?
This is an OSX El Capitan version
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 5
Accepted Solutions
JamesGL
Master
Re: connectivity problem R7000
Hi wabbak,
Reset the router to factory default and reconfigure it manually.
Message 5 of 5
All Replies
JamesGL
Master
Hi wabbak,
Check for the firmware, make sure it is updated.
Try changing the channels of your wireless network.
Message 2 of 5
JamesGL
Master
Hi wabbak,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 5
wabbak
I updated the firmware, but I didn't change the channel, because I'm the only one hear, nobody else is on any channel, so that won't make a difference. I am on my MacBook, with WiFi connection. My phone is next to me and I do not have a connection. What is wrong???
Message 4 of 5
JamesGL
Master
Hi wabbak,
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3169 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
