Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
disable port scan and dos protection
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-09-29
03:00 AM
2014-09-29
03:00 AM
I need help from experts
Is there any Reason why this should be enabled? On my old Router is was disabled (default) and I´m not sure if I should disable it or enable it.
I user Port Triggers (port 3074 TCP/UDP for my xbox).
Like I understand a home Router can´t help you if you ar Dosed? And the DOS Protection has to process every Incoming packet.
Is it right, That i doesn´t really help?
If it only is dos protection I would disable it - but what does "port scan" in "disable port scan and dos protection" do?
Is it a security Problem if I disable it?
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-09-29
08:06 AM
2014-09-29
08:06 AM
Re: disable port scan and dos protection
Disabling logging for these attributes will not pose a security risk. You are not making yourself any more vulnerable not logging these types of attacks.
They are there for monitoring and will provide a record in general terms for the types of threats and traffic your WAN sees.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
~EX3700 FW:1.0.0.84
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-09-29
12:18 PM
2014-09-29
12:18 PM
I don´t mean the logging of this but I mean the WAN Configuration.
Is it a security Risk to turn it off?
Message 3 of 3
Top Contributors
User | Count |
21 | |
15 | |
9 | |
8 | |
4 |
