- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ea6100v2 config utility?
- Mark as New
- Bookmark
- Subscribe
- Permalink
why isn't there a config utility that runs on windows? What giant ****** decided to make phone apps only?
what am i supposed to do???
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ea6100v2 config utility?
You can use the installation assistant. its easy to use and doesn't need a phone/app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
They didn't. They just try to force you down that router because it is "simple". It is also annoying that they don't make it more obvious that there are alternatives.
Use a browser?
I don't know what the ea6100v2 might be. I cannot find it in the Netgear database and Google is equally ignorant.) But the documentation should guide you through the process.
