Orbi WiFi 7 RBE973
Reply
ethernet ports leds blinking red when ethernet cable connected
DFunnell
Follower
The ethernet ports are flashing red when connected, is this correct if not what colour should they be and how  do I rectify the problem
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 2
Accepted Solutions
microchip8
Master
Re: ethernet ports leds blinking red when ethernet cable connected
Google for the documentation of the router! Read and you'll see that red means its operating at 10 or 100 Mbps. White means it's operating at 1 Gbps (1000 Mbps).
If you have something plugged in that only supports 10/100 Mbps, then you'll get red
Message 2 of 2
All Replies
microchip8
Master
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 12381 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
