Reply
extender
HD98
extender
I have two extenders , the first one that I have set up shos up as DREAM TEAM EXT_2 and EX_5 , but when I set the second one up it doesnt show anything at all , but all the lights will be green. How do I set it up where it will have its own set of identifiable properties so I can have certain things connected to each one.
Model: EX6110|AC1200 Dual Band WiFi Range Extender
Message 1 of 7
Re: extender
@HD98 wrote:
I have two extenders ...
Both set up as wifi repeaters? Or is there an access point in there?
Shows up in what? Do they both appear as connected  in whatever router feeds them?
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
Those things are very different from the standard Netgear routers covered in this section.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 7
Guru
Re: extender
Are both extenders EX6110?
Or what actual models do you have?
What router are you connecting them to?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 3 of 7
HD98
Re: extender
Yes both models are the same. So one will be connected and the other won't, be if I unplug one , then the other one will work. I need both to have their own properties ,is that possible, and the router is my xfinity router
Message 4 of 7
Guru
Re: extender
Please visit and post about WiFi Extenders here:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Might find more information as well.
Thank you.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)> RBK953(v6.0.3.68) & XR450(v130)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 5 of 7
Re: extender
Thank you.
This is, of course, the same link that was posted several messages ago.
Re: extender - NETGEAR Communities
And the bit that says:
 I suppose there is nothing wrong with repeating these things, although it does lead to a very messy conversation.
Just another user.
Message 6 of 7
Guru
Re: extender
Just a reminder. Thanks.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 194 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
