Reply
firmware V1.0.2.20 and ipv6
01R
Luminary
Luminary
any 1 notice anything wird with this firmware an ipv6  after installin it the router says i got ipv6 but the pc cant get ipv6 the thing says no internet next to the ipv6 any 1 else see this happen ?
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 2
01R
Luminary
Luminary
Re: firmware V1.0.2.20 and ipv6
ok it seems i solved the problem in the ipv6 lan setup section if you leave it to use dhcp server  the router gets an ipv6 address but everything behind the router wont you have to change it to auto config and then everything behind the router gets an ipv6 address  did it work this way be4 ?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2227 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
