Orbi WiFi 7 RBE973
Reply
firmware update
summit
Follower
firmware update
The Netgear Nighthawk X8 R8500  router was uinstalled and all the devices were added using  a new SSID and Password.  The tech forgot or didn't take the time to do a firmware update.  If I do a firmware update now, will I have to reinstall the devices after the router reboots after installing the upgrade?
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 2
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: firmware update
Hello @summit
Welcome to the community!
We normally recommend a factory reset after firmware upgrade. This is just to ensure that everything is back on its default settings and nothing can cause possible problems.
Now, doing a reset will require you to reinstall the settings on the unit just like when you first had it.
For reinstallation, you may see this link.
Message 2 of 2
All Replies
ElaineM
Re: firmware update
Hello @summit
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3403 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
