Reply
vand1
Follower
firmware version issues
The listed Firmware version on ../000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router is V2.02.04.  In Genie on my modem it is V4.02.02 (
Hardware Version1.01
Firmware VersionV4.02.02
Does anyone know what gives?
Thx
D
Model: CM1150V|DOCSIS 3.1 Nighthawk® Multi-Gig Speed Cable Modem for XFINITY® Voice
Message 1 of 2
labatt
Prodigy
Re: firmware version issues
What gives is you are at the mercy of your ISP, I am assuming Comcast in your case.
You cannot update the firmware on your cm1150v it is up to the ISP to update fimware connected to their network. In my experience with 3 different Netgear modems connected to Comcast they were never updated. In my case I did not care as they just worked. Reason for more then one was speed increases needing different modem. Current cm2050v is just purring along.
Never tried, maybe if you call they will update it. Don't know as had no issues with the current firmware.
Modem CM2050V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 307 views
  • 0 kudos
  • 2 in conversation
Announcements
