Orbi WiFi 7 RBE973
Reply
firmware
robimac
Follower
firmware
Ciao a tutti, ieri ho aggiornato il mio router r8000 x6 con ultimo firmware, ma questo non è andato a buon fine.
Ora lampeggia con luce bianca, mi potete dire come fare a ripristinarlo? Grazie
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
Accepted Solutions
Guru
Re: firmware
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 2 of 2
All Replies
Guru
Re: firmware
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 581 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
