Reply
Highlighted
ftp issues with Foscam R2 camera
I try to setup the FTP with my foscam camera.
Connecting via filezilla to the r7000 is no problem
Connecting with the camera to te ftp server = error.
Connecting with the camera to another FTP server (outside network) is no problem.
So the combination of the R7000 ftp and the Foscam does not work.
i have read other topics but no solutions provided. Smiley Sad
updatet the firmware yesterday for the foscam and netgear.
how can i debug this issue?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 7
Highlighted
Retired_Member
Not applicable
Re: ftp issues with Foscam R2 camera
It may be a nat loopback problem which netgear doesn't support ( from what I've heard)  which I'm guessing and in no way an expert. But using a 3rd party FW may solve the problem.
http://www.linksysinfo.org/index.php?threads/asuswrt-merlin-on-netgear-r7000.71108/    I am using this on my r7000 and it works great. It also has a NAT Loopback Option
http://www.networkwebcams.co.uk/blog/2012/06/11/what-is-nat-loopback/
Message 2 of 7
Highlighted
Unfortunately this is not my problem, because on the camera i use the local IP address of the ftp server. So i should not go outside my local network. Then again, it should i cannot check that. Smiley Sad
Alternative firmware for me is the last solution.
Thanks anyway.
Message 3 of 7
Highlighted
Retired_Member
Not applicable
For years I thought 3rd party was taboo, But I finally got fed up and after seeing this Xwrt-Vortex I started reading about it. It's worth looking into. It's as easy to load as stock FW and also just as easy to revert back to stock. Eitherway good luck.
Message 4 of 7
Highlighted
You are right,
i got 1 router working wit tomato, and 1 with dd-wrt but they both have more options i do not use in stead of using. Most options i do not even know what is is Smiley LOL
Message 5 of 7
Highlighted
Retired_Member
Not applicable
Yes and this one is more in line with OEM ....it's not as complicated as other 3rd world versions.
Message 6 of 7
Highlighted
I wil tyake a look at it.
reading the website off Xwrt-Vortex looks nice. VPN client looks promising
Thanks.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 3068 views
  • 0 kudos
  • 2 in conversation
Announcements
