Reply
having problems with my R7000
Duka2
im having a problem resetting to factory settings.  ive held the reset button for more then 30 sec.  and using an ehternet cable tryed to log into www.routerlogin.net  the admin / password doesnt work so the next screen asks for the serial number, so i enter it and it says it doesnt match the router?  so i log into my netgear account and it shows the right equipment and the same serial number?  so im stuck? any suggestions?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
antinode
Guru
Re: having problems with my R7000
> [...] ive held the reset button for more then 30 sec. [...]
   Try it again, with nothing connected to the R7000 (except its power
adapter).  Do the LED indicators do anything interesting?
   If a settings reset does not help, then you may be a candidate for
the TFTP recovery scheme.  See, for example:
      https://community.netgear.com/t5/x/x/m-p/1533866#M87578
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 241 views
  • 0 kudos
  • 2 in conversation
Announcements
