jiao
Nov 29, 2020Tutor
how can I check Orbi RBR50 CPU and RAM usage
How to check Orbi AC3000 CPU and RAM usage? I attached about 40 device with lots of traffic, I'd like to know if it still work healthy. I might need to add another satelite, not sure the whole system can afford it or not. anyway to check CPU and RAM usage?
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
