× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 3 replies
  • 371 views
  • 0 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
how to connect and access Samsung T5 SSD on my R8000
i have a R8000 router.  I am trying to connect Samsung T5 SSD, 500GB, to back of router, USB 3 port.
But, cannot see it connected, in ReadyCloud, or access from any other device, such as a Samsung Smart TV or my iPhone, etc.
I have tried to follow the directions, but they are woefully inadequate.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
Highlighted
Guru
Re: how to connect and access Samsung T5 SSD on my R8000
A couple things.
1. have you checked to see if its compatible with your router?
https://kb.netgear.com/18985/Will-my-USB-drive-work-with-ReadySHARE
If its not on the list, it might still work.
2. Is the hard drive in the correct format?
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-my-Nighthawk-router
CM1100->RAX200->GS716v2->RBR50->RBS50-RBS40V-RBS50Y
Message 2 of 4
Highlighted
Prodigy
The Samsung T5, I have one, it’s comes default formatted to exFAT which is not supported by the router. You need to format it as any of the following; NTFS, FAT32, EXT2 or EXT4 for it to work.
Message 3 of 4
Highlighted
Prodigy
Here’s actually the full list of supported formats:
FAT16, FAT32
NTFS
NTFS with compression format enabled
Ext2, Ext3, Ext4
XFS
HFS
HFS+
exFAT is slowly being added to the Linux 5.4/5.5 Kernels in the latest versions so maybe NG may backport it in the future once it’s stable/good enough. The RAX120 I believe uses Linux Kernel 4.4.60.
Message 4 of 4
