Reply
how to open the R7500
LordSvendsen
Follower
Hello, does anyone know how to open a netgear R7500? One of the antennas broke and i want to open the box so i can remove the loose part.
I unscrewed the screw on the rear of the router but there is no movement whatsoever
LordSvendsen Smiley Wink
Model: R7500|Nighthawk X4 AC2350 Smart WiFi Router
Message 1 of 2
Guru
Re: how to open the R7500
You should post here for help with this:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 337 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
