Reply
how to transfer files between 2 computers via RJ45 for faster speed
inov8iv
Hello everyone,
could someone please help:
1. old computer has RJ45
2 new computer has USB3.0 - have have attached a USB3.0 to RJ45 dongle.
3. connected both ports to the R7500 router
4. how can i transfer files from my old computer to the new one at a faster datarate than the wireless computer share method.
appreciate your help..
thanks.
Model: R7500|Nighthawk X4 AC2350 Smart WiFi Router
Message 1 of 3
IrvSp
Master
Re: how to transfer files between 2 computers via RJ45 for faster speed
It really is 'easy' with one little thing to do. That is have the proper permissions so the PC's can see/read/write to each other.
Depends on operating systems used though. Once you get the permissions in order you can copy files just like you would on a PC with 2 drives.
Google "set up a home network" and you'll find a lot of help and even You Tube video's on what to do. Add in the search your OS and you should be able to handle it.
Message 2 of 3
inov8iv
thanks so much!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 557 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
