Reply
https management on R7000
Speeder29007
Follower
Can we please have a Feature Request (FR) to add HTTPS (SSL/TLS) management  to the R7000.
Is there a reason why the R7000 doesn't utilize SSL for management internally? I see if you configure external remote access, you can use TCP 8443 but I see no option for internal use.
I'm sure the whole community would benifit from this.
Thank you.
Message 1 of 2
ElaineM
NETGEAR Employee Retired
Re: https management on R7000
@Speeder29007 I strongly suggest that you post this feature request under our Idea Exchange board.
By the way, thank you for your suggestion.
ElaineM
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1923 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
