- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
interferes with phone system
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ever since I installed the Router, my phone system has been acting up. I use 8x8 VoIP. THey seem to think the problem is the router and the setup. I am not sure if that is it or something else. Any suggestions?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Disable the SIP ALG, then cold boot your VoIP phones again.
How to disable SIP ALG on your NETGEAR device using the genie interface
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: interferes with phone system
Well, I don't know what you have in the way of the VioP system, but I'd suggest posting the the correct forum, https://community.netgear.com/t5/Cable-Modems-Routers-and-DSL/ct-p/en-home-dsl-and-cable-modems. In addition, supply some real information, "my phone system has been acting up" doesn't convey to me anything to even suggest.
Also say what you had when it did work and what was changed? General router settings as well would help so maybe someone could suggest what to change.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Your footer says that you have a C7000.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. This is easily done, given Netgear's impenetrable community structure.
The C7000 is a Cable Modem/Router.
You might get better replies, and find other answers, over in the appropriate section:
Cable Modems & Routers
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thank you. That solved my issue
