- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
internetspeed is way below IPS
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I see several items on the issue but can"t make out an solution.
My ISP provides 500Mbps download but i only get max 170Mbps download.
In statistics i see dat the LANMports are 1000/full ....
Does someone have a solution
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Glad to hear it helped! If you mark it solved it can help the next person with this issue
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: internetspeed is way below IPS
What modem/gateway do you have?
What firmware is on the router?
have you tried a simple factory reset and reinstall? Make sure to leave qos, traffic monitoring, access control, and parental controls disabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
My IPS is a router (Connectbox don'n no the brand) in bridgemode and direct acces gives me more than 500Mbps. My router R7000/RC1900 FW: V1.0.11.106.10.2.100
Qos, traffic monitoring, access control, and parental controls are disabled.
Have not tried a factoryreset... Wil do that...question i can later on load all my settings from a backup ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
.... the funny thing is that my Wifi speed is 260Mbps and on Lan 170Mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Hijack wrote:My IPS is a router (Connectbox don'n no the brand) in bridgemode and direct acces gives me more than 500Mbps. My router R7000/RC1900 FW: V1.0.11.106.10.2.100
I wouldn't use a backup if it fixes the issues.
I'd also recommend trying version 1.0.9.42 of the firmware for the R7000. install that, factory reset, and clean install. (don't use a backup)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
solved 😀
I did the factory reset and speed was OK, loaded my backup and speed was again way below. Did factory reset again. Speed again OK. Applied manually my old settings (I used exactly same settings as my backup). Speed was still OK. I didn't need to use the older firmware. A bit strange that the setting are exactly the same as the backup but with manually input it all worked fine...
Thx for helping me
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
