× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 5 replies
  • 225 views
  • 0 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
latest firmware
Has anyone updated to latest firmware on R6700? Mine has been running over 30 minutes.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 6
Highlighted
Prodigy
Re: latest firmware
You are asking because? Are you having issues?
Modem CM1150V
Message 2 of 6
Highlighted
Re: latest firmware
Yes and actually it bricked my router
Message 3 of 6
Highlighted
Prodigy
Re: latest firmware
Since you say it is running you must have recovered the router.
Make sure that auto update is disabled so no unexpected surprises.
Modem CM1150V
Message 4 of 6
Highlighted
Re: latest firmware
Sorry I have not been able to recover router. Cannot get a new firmware load via TFTP to work either. Not sure what else to try. Any ideas ?
Message 5 of 6
Highlighted
Sensei
Re: latest firmware
> [...] Cannot get a new firmware load via TFTP to work either. [...]
   "Cannot" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] Not sure what else to try. [...]
   Not sure what you _did_ try.
   The TFTP recovery scheme is a multi-step procedure which offers
multiple opportunities for user input, hence user error.  Saying that
you tried TFTP, with no details (your preparation steps, the actual
command which you used, the actual error message which was emitted, and
so on), conveys practically no useful information.  Especially when
using a command-line program, copy+paste is your friend.
> [...] Any ideas ?
   As a start, provide a problem description with some useful
information?  What, exactly, does "bricked" mean to you, in terms of LED
status/activity and/or router response to a web browser or TFTP client
program?
Message 6 of 6
