Orbi WiFi 7 RBE973
Reply
limited users on 2.4ghz band
luivan
Follower
Hello, I have an R8000 triband router in my home, my problem is that the 2.4 band is limited to 32 users, I dont have many persons that use the internet, but I just buy a lot of light swiches to make my home smart, and every device use an ip of my network and only work in the 2.4 band not the 5 band
What do I need to buy or to do to increase the number of users in my 2.4 band? any ideas?
Model: R8000P|Nighthawk X6S—AC4000 Tri-Band WiFi Router
Message 1 of 2
Accepted Solutions
antinode
Guru
Re: limited users on 2.4ghz band
> [...] my problem is that the 2.4 band is limited to 32 users [...]
> [... What do I need to buy or to do to increase the number of users in
> my 2.4 band?
   Add a wireless access point (probably with a different SSID)?
   If you can run a cable from the R8000 to a neighborhood where some
low-demand devices on the 2.4GHz band reside, then almost any cheap/old
router could be employed.
Message 2 of 2
All Replies
antinode
Guru
> my 2.4 band?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 377 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
