Orbi WiFi 7 RBE973
Reply
my router won’t reconnect
bagjunah
Follower
powered off then back
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 4
Guru
Re: my router won’t reconnect
Doesn't give us much to go on.
Reconnect to?
Can you confirm the brand and model# of your router?
Message 2 of 4
Is the A7000 WiFi USB Adapter listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
Message 3 of 4
wcalifas
Prodigy
do you have cable internet? If so you have to reboot the modem and wait til it connects to your provider then you turn on the router to detect the internet.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 576 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
