- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
netgear AX6/AX5200 RAX48-100NAS DNS address change not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have a netgear AX6/AX5200 RAX48-100NAS router and I wanted to change the primary and secondary DNS addresses to the servers OpenDNS uses. I was not able to make the change as after I hit the 'apply' button the changes were never applied or saved.
I tried to use both dynamic and static IP address options but they didn't make a difference.
Has any one encountered this problem before? Any thoughts on what I do wrong and what could be the remedy?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: netgear AX6/AX5200 RAX48-100NAS DNS address change not working
have you tried using a different browser or pc?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
what modem/gateway do you have?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you using ipv6?
Have you tried a simple factory reset/reinstall?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I factory reset my router twice to no avail. I tried to adjust the DNS setting via the nighthawk app but they were grayed out, wasn't allowed to make any changes
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can try the auto-detect with the IPv6. works in most cases.
If it doesn't, then try downgrading the firmware a version.
