Reply
netgear R9000 Satic Routing
Adamclarkson202
Follower
I am wanting to use static routing for a server on my network that doesnt have a Internet connection.
Is there a way to gain internet access without using a proxy server.
my Server has the following
IP Address: 10.1.1.7
Sub: 255.255.255.0
Gateway 10.1.1.1 (Domain Controller)
DNS: 10.1.1.1 (Domain controller.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 2
antinode
Guru
Re: netgear R9000 Satic Routing
   Could you explain what you're doing in a way that makes any sense at
all to the non-psychics in your audience?
   Is there some actual problem which you are trying to solve?  As
usual, you might get better advice if you described the actual problem
which you are trying to solve, rather than asking how to implement some
particular "solution" ("use static routing") which may have little or
nothing to do with your actual problem.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 202 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
