- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
netgear X4 , starlink
- Mark as New
- Bookmark
- Subscribe
- Permalink
many other devices just hook up with wifi password . Why not this extender
Starlink extender needed !!!!!
Said nothing about not compatible till after you buy and try to hook up
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: netgear X4 , starlink
X4 doesn't mean much here in the forums.
What NG product are you referring too? Router, extender?
Contact the mfr of starlink for help and informatino regarding there product.
- Mark as New
- Bookmark
- Subscribe
- Permalink
problem is not starlink works fine with no extender . starlink router has no wps buttons .
message came “ your router ( starlink standard ) is not compatible with starlink .
you find that out after buying it !
- Mark as New
- Bookmark
- Subscribe
- Permalink
did you try installing it using the installation assistant?
the EX7300 is an extender only. not a router.
so you need to make sure your starlink router is running (and usable), then set it up using the installation assistant.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is no guarantee the extender will work with Starlink. It's not even certified for it. Next time do a bit of research if you want compatible Starlink devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the model of this Starlink device?
Too many people get the impression that Netgear routers lack WPS. In reality, they just haven't found it, partly because this feature isn't always easy to find.
Perhaps Starlink is equally obscure.
