- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
netgear ac1900 model c7000v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
This cable modem and router worked very well in my 850 sf home . I'm in a 2,000 sf home now and there are dead spots, or the signal will just drop. I have heard that a mesh network is the way to fix this issue. However, I don't want to replace this cablr modem / router. What mesh systmenworks well with tis modem/router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: netgear ac1900 model c7000v2
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
- Mark as New
- Bookmark
- Subscribe
- Permalink
2000sqft isn't a huge size. Usually 1 router can cover it if its centrally located and the home materials don't block wifi.
If you do look at extenders, I usually recommend the triband mesh extenders. They high lower latency, higher throughput, and tend to be more stable.
