zkiller1236
Oct 12, 2021Follower
netgear ex7300v2 blue arrows amber power
i had a power short and now my ex7300v2 is pinting blue arrows and the power is amber
what do i do?
1 Reply
First try factory resetting.
Push and hold reset for up to 30 seconds while powered on.
if that doesn't work,
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
