Reply
netgear nighthawk 7000 wan connecting to internal ip?
dd97
Hi. I am having a strange issue. Sometimes, my WAN link to my ISP goes down and the router ends up getting a 192.168.100.10 ip. My firmware version is v1.0.9.88_10..2.88. Here is my log. Happened twice so far today.
[Admin login] from source 192.168.1.2, Sunday, Jan 19,2020 10:04:51
[DHCP IP: (192.168.1.8)] to MAC address 64:16:66:A4:F4:26, Sunday, Jan 19,2020 10:00:36
[Time synchronized with NTP server] Sunday, Jan 19,2020 10:00:23
[Internet connected] IP address: x.x.x.x, Sunday, Jan 19,2020 10:00:22
[Internet disconnected] Sunday, Jan 19,2020 10:00:18
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 10:00:02
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:59:52
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:59:32
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:59:19
[DHCP IP: (192.168.1.5)] to MAC address 64:16:66:AC:E5:74, Sunday, Jan 19,2020 09:59:10
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:59:10
[DHCP IP: (192.168.1.8)] to MAC address 64:16:66:A4:F4:26, Sunday, Jan 19,2020 09:59:00
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:58:59
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:58:49
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:58:30
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:58:19
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:58:09
[DHCP IP: (192.168.1.5)] to MAC address 64:16:66:AC:E5:74, Sunday, Jan 19,2020 09:57:28
[Internet disconnected] Sunday, Jan 19,2020 09:57:19
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:57:01
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:56:42
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:56:22
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:56:07
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:55:48
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:55:28
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:55:15
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:55:05
[DHCP IP: (192.168.1.9)] to MAC address E4:2B:34:5E:D9:42, Sunday, Jan 19,2020 09:55:02
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:54:54
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:54:35
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:54:13
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:54:02
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:53:52
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:53:33
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:53:23
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:53:12
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:52:53
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:52:33
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:52:22
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 09:52:12
[Internet disconnected] Sunday, Jan 19,2020 09:52:09
[DHCP IP: (192.168.1.6)] to MAC address 08:66:98:B1:A7:58, Sunday, Jan 19,2020 09:27:08
[Time synchronized with NTP server] Sunday, Jan 19,2020 08:37:38
[Internet connected] IP address: x.x.x.x, Sunday, Jan 19,2020 08:37:36
[Internet disconnected] Sunday, Jan 19,2020 08:37:32
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 08:37:15
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 08:37:05
[Internet connected] IP address: 192.168.100.10, Sunday, Jan 19,2020 08:36:55
[Internet disconnected] Sunday, Jan 19,2020 08:36:52
[DoS attack: ACK Scan] (3) attack packets in last 20 sec from ip [13.225.49.49], Sunday, Jan 19,2020 07:59:29
It does finally get a valid IP and I get my connection back, but just wondering if there is something else happening here security-wise that I should be concerned about.
Thanks for looking!
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 7
DarrenM
Sr. NETGEAR Moderator
Re: netgear nighthawk 7000 wan connecting to internal ip?
does this happen with all your devices that try to connect to the network?
DarrenM
Message 2 of 7
schumaku
Guru
Various CPE, ISP routers, ... default to a private subnet LAN if the connection to the Internet/ISP is "offline" or not properly provisioned by the ISP, and also run a DHCP server for this subnet. Here it's 192.168.100.0/24 and your router does get .10 assgined from that device.
What can be even worse? Other CPE default to the common 192.168.0.0/24 or 192.168.1.0/24 network - then the Netgear routers will reconfigure their LAN to an alternate subnet - and the mess will be perfect. What seems to be a commodity design, it's a nightmare in a LAN with more than just a few comuters or mobile on the LAN.
Message 3 of 7
dd97
oh ok, so the netgear firmware gives itself that IP when the ISP connection is screwed up? and then keeps on trying to reconnect?
Message 4 of 7
schumaku
Guru
No, the ISP CPE (e.g. cable modem, fiber box, ...). The "Internet" does shrink to minimalistic set-up with the ISP provided CPE and your Netgear router.
Message 5 of 7
dd97
the cable modem is mine btw, I bought my own to not pay rental fees. do you think it could be nearing end of life? or is this just upstream issues you think?
Message 6 of 7
schumaku
Guru
Upstream (check with your cable ISP) issues, or local cable modem problems indeed.
If you have some access to the cable modem logs, you might get some insight, too.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 768 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
