- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
netgear suppor is worthless!!! I hope you can help
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ok, so netgear suppor is Fking worhless, making me reach out to the 'community', so I hope you can all help!
I'm trying to retreive the admin password for my R700 router, but the www.routerlogin.net site is messed up. I follow the directions and go to the site. I select cancel as instructed. However, once I enter the serial number into the field, there is no 'continue' 'button'. I've attached photos. I am using chrome also as instructed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: netgear suppor is worthless!!! I hope you can help
Try looking up in the support pages the model of your router. Use the documentation/manual to see how to reset to manufacturer specs. Pushing and holding a button for 3 or more seconds should take care of that reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Not much the community can do for you. If this...
How do I recover the admin password on my NETGEAR router?
...does no work as expected (many potential reasons - have tried a reboot before, disabled any borked Internet "security" packages intercepting Web traffic, ...? It's not a "site" by the way, it's a Web page hosted on your router.), as suggested in brief before, reset the router:
How do I perform a factory reset on my NETGEAR router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have seen reports of that before. If you didn't set up password recovery, but haven't turned it off, then there's a bug that leaves you in a closed loop.
The only solution is a factory reset, use the default password and reconfigure the thing from scratch.
Then either set up password recovery, or disable it completely.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40VUser | Count |
15 | |
10 | |
9 | |
5 | |
4 |
