Reply
new firmware guys
Bigcid10
Guide
new firmware guys
{Mod - link removed - only link to Netgear servers please} flashed it on mine already no issues just popped up there this morning
HW-E i7-5930K
MSI X99S GAMING 7
Corsair H110
16GB(4X4GB) GSKILL RIPJAWS4 DDR4 2400
Coolermaster silent pro1000 PS
PowerColor PCS+ R9 290 4GB GDDR5
BenQ XL2720Z
2 Kingston HyperX 3k 240GB ssd Raid0 for OS
corsair 800D
Asus Essence STX II 7.1 | Logitech Z-5500
Windows 8.1 x64 mce
netgear r7000
V1.0.4.4_1.1.37
Message 1 of 41
Retired_Member
Not applicable
Re: new firmware guys
Message 2 of 41
pingjockey
Tutor
So was there any changes worth flashing a beta?
Message 3 of 41
RogerSC
Virtuoso
searay, Do you know if this includes the IPv6 fixes that we've seen from the *57* debug builds yet? It might or might not, depending on how they do source control; i.e. the source for those *57* fixes (if on a branch) would have to have been merged into the *60* source trunk or branch. If you know what I mean *smile*. I may be attributing more source control functionality to them than they actually use, though.
Message 4 of 41
Bigcid10
Guide
seeing that there wasn't a change log listed ,one would have to make a decision here
I made the decision to load it and see what happens and I didn't the other beta to go by
and the 56 release was wireless hell,the decision was easy
HW-E i7-5930K
MSI X99S GAMING 7
Corsair H110
BenQ XL2720Z
corsair 800D
Windows 8.1 x64 mce
netgear r7000
V1.0.4.4_1.1.37
Message 5 of 41
ericnix
When should we expect a final version to be released? (Not sure how long Netgear usually beta tests.)
Netgear R7000
DD-WRT Kong 24345
overclocked to 1.2 GHz
Message 6 of 41
jsmiddleton4
Tutor
Last firmware seemed to make everything snappier. From that firmware to this beta I do not see that kind of speed improvement. Also the things I have turned off like Parental Controls and Guests Network showed red due to being disabled. So far they are still green.
Other than that I don't see anything that smells like an early beta release. Loaded fine and seems stable. Wireless clients not dropping but I did not have a problem with that before.
Message 7 of 41
Retired_Member
Not applicable
Rodger,
Don't bother with this one if you're looking for the IPV6 fix. Just confirmed it's still broke stay on the current one.
Message 8 of 41
RogerSC
Virtuoso
Thanks for saving me the trouble *smile*, I'll stay where I am then.
Message 9 of 41
Squuiid
Luminary
I had been issued this beta last week, change log given was:
"system and WiFi stability improvements"
So far so good... no lock ups on bridge mode, yet.
Message 10 of 41
Bigcid10
Guide
61
{Mod - Netgear do not allow linking to third party firmware sites}
no changlog
HW-E i7-5930K
MSI X99S GAMING 7
Corsair H110
BenQ XL2720Z
corsair 800D
Windows 8.1 x64 mce
netgear r7000
V1.0.4.4_1.1.37
Message 11 of 41
pingjockey
Tutor
Looks like R7000-V1.0.3.61 was just posted at the same place as yesterday. Interesting....
Message 12 of 41
Bigcid10
Guide
look up I looked into this one and I see as new VLAN/IPTV Setup Facebook Wi-Fi plus the readyshare readycloud feature for external hdd
HW-E i7-5930K
MSI X99S GAMING 7
Corsair H110
BenQ XL2720Z
corsair 800D
Windows 8.1 x64 mce
netgear r7000
V1.0.4.4_1.1.37
Message 13 of 41
jsmiddleton4
Tutor
I didn't think we are supposed to post links to third party sites?
Message 14 of 41
RogerSC
Virtuoso
VLAN/IPTV Setup
Facebook Wi-Fi
Stuck testing WRT1900AC, oh well *smile*.
Interesting that it has "QA" in the version string, almost as though it were a release candidate that Netgear is testing *smile*. We'll see, I guess. They may go through several release candidates before they're happy.
Message 15 of 41
Retired_Member
Not applicable
Message 16 of 41
Retired_Member
Not applicable
searay wrote:
ftp://downloads.netgear.com/temp/
This one appears to have the IPV6 fix. just tested it. .61
Message 17 of 41
ericnix
When you guys install firmware updates, do you factory reset before and then reconfigure everything manually or do you use a backup of your previous configuration?
Netgear R7000
DD-WRT Kong 24345
Message 18 of 41
SkyOwl
Guide
Huge difference in file size between .60 and .61....makes one wonder what else is in it?
Message 19 of 41
Retired_Member
Not applicable
I saw that too, one thing implicit BF is broken Leave it off. Throughput 15 on 47Mbps off
Message 20 of 41
Retired_Member
Not applicable
Looks like it added FaceBook Like me option.
I usually do reenter a fresh manually entered config. In this case I didn't only because I did last night with .60. I'll do it later to night when everyone is a sleep.
Message 21 of 41
ericnix
I have about 30 reserved IP addresses so I prefer not to manually enter them again as long as it doesn't adversely effect the firmware upgrade process.
Netgear R7000
DD-WRT Kong 24345
Message 22 of 41
Retired_Member
Not applicable
You're better off resetting to defaults and configuring from scratch. Even though it appears things sometimes work, it can create strange quirkiness down the road...
Message 23 of 41
Retired_Member
Not applicable
Your choice, I have 12 reserved and it doesn't take that long if you leave them on, most show up as attached with correct info and it's a matter point and click.
Message 24 of 41
cc999
Whats the verdict, should we install?
CC
Message 25 of 41
Top Contributors
Discussion stats
  • 40 replies
  • 15173 views
  • 0 kudos
  • 14 in conversation
Announcements
