jdbillson's avatar
jdbillson
nighthawk 7800 admin password reset
how can i reset my admin password if I cant answer my security questions? I seriously think someone hacked me and changed the security answers.
  • michaelkenward's avatar
    michaelkenward
    I doubt it. Did you ever set the security questions?
    If you are trying to use the "password recovery" option, there is a bug in Netgear's implementation of password recovery on some devices. You can get locked into a closed loop.
    If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process. If you haven't already given the thing your personal answers, they are not in its memory and it has no way of knowing if they are correct.
    If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.
    How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
