Discussion stats
  • 4 replies
  • 184 views
  • 2 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
nighthawk R7400 region change
Hi! I need your assistance with changing the region from United States to Greece on a nighthawk r7400. Is it possible?
Thank you very much all for your time!
Model: R7450|Nighthawk AC2600 Smart WiFi Router
Message 1 of 5
Highlighted
Luminary
Re: nighthawk R7400 region change
In some countrys maybe buy as far as i know routers made for the US are locked to that region per FCC rules. So to answer your question no its not likely you can change the region from US.
Asus RT-AX58U. Merlin 384.18_Alpha 1
(AT&T Fiber, Gigabit)
Message 2 of 5
Highlighted
Thank you for your reply!
Message 3 of 5
Highlighted
If you are talking about the wifi network, it may be locked on to the USA by order of the FCC. There are ways to change it. They involve arcane tricks with Telnet.
Solved: WNDR3700v2 (N600) - Can't change wifi region - NETGEAR Communities
Search for burnsku.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 5
Highlighted
Thank you! I will check it out.
Message 5 of 5
