Orbi WiFi 7 RBE973
Reply
nighthawk access w/o internet
jackcraigaptos
while my router works fine, when the internet goes down, i lose access to rtr.
when net is down i need acess most.
pls point me to the docs for this issue, but i was unable to find it.
tia..
Message 1 of 11
Accepted Solutions
IrvSp
Master
Re: nighthawk access w/o internet
On a router when connected, the router gives your devices an IP address via its DHCP. That creates the LAN. You ISP via the modem provides the Internet signal to the router and it had the WAN IP Address. You do NOT need the Internet signal to the router to access the router. Just use a Browser as mentioned above.
What I don't understand is "ip not responding w/o intrernet connection and login.net requiers internet for dns, right??"? Where did you get that idea from?
"what is the next step? if i use the yellow cable and plug it pc to lan port 1, is that the secret back door?"
Why do you think this is valid? There is no 'secret backdoor'? Use a BROWSER to log into the router.
"i did verified 192.168.1.254 responded to ping when entire lan to wan is up, ..."
Totally confused with that statement? I'm beging to think you are not connected to the router but you modem is also a router? What is your modem make and model? What is the IP Address of your PC?
Message 10 of 11
All Replies
JoseAndres041
Luminary
Once you don't have access to Internet, check your device's IP address. Ping your router and if it's replying, then you should be able to access your router.
Message 2 of 11
jackcraigaptos
i think it might be working fine as it's performing other network ativites, but ill try it.Thx for your tme to reply
Message 3 of 11
jackcraigaptos
i have Not been able to take that nework down to verify. i will get this done in the next 24h.
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 4 of 11
schumaku
Guru
In case there is a ISP CPE in front of the router (e.g. a cable modem, a router, ...) which does fall-back to issue RFC1918 private IP addresses - and if this is overlapping with the router LAN subnet - the routers are (unfortunately) overly "smart" and reconfigure the local subnet to some 10.x.x.x /254
Message 5 of 11
IrvSp
Master
tia..
Are you using the Netgear Nighthawk app to access the router? If so, you need Internet access.
If you have LAN access, use a Browser to log into the router's IP Address (or ROUTERLOGIN.NET) to reach it and login.
Message 6 of 11
jackcraigaptos
after internet disconnect, i am unable to access router and i need to
my host env is linux/macos, and i dont use cell phone apps.
my apologies or taking so long to test, trip out of town.
there has to be a way to access this router w/o internet access.
suggestions? Thx!!
Message 7 of 11
jackcraigaptos
next?? Thx tho,...
Message 8 of 11
antinode
Guru
> to rtr.
   What, exactly, does "lose access" mean to you?  As usual, showing
actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
   Is that accurate?  Firmware version?  Connected to what?
> is up, ...
   What's at "192.168.1.254"?  The default LAN IP address of an R8000P
is "192.168.1.1".
> after internet disconnect, i am unable to access router [...]
   When you do what?  "unable" is not a useful problem description.  It
does not say what you did.  It does not say what happened when you did
it.  See "As usual, [...]", above.
> what is the next step? [...]
   Explain what you're doing, and what happens when you do it?
> [...] if i use the yellow cable and plug it pc to lan port 1, is that
   Huh?  Which "the yellow cable"?  Where is it connected now?  Why
would you need a "secret back door" to anything?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  If it were impossible
to communicate with a router until you have an Internet connection, then
how could anyone configure a new router?
> ip not responding w/o intrernet connection [...]
   I don't know what that means to you.  "IP" = Internet Protocol.  See
> [...] and login.net requiers internet for dns, right??
   No, using "routerlogin.net" does not require Internet access.  A
Netgear router should handle such a reference locally.
Message 9 of 11
IrvSp
Master
Message 10 of 11
jackcraigaptos
the posed queries identified my problem. wrong ip.
firmware V1.4.1.42_1.3.4
routerlogin.net did resolve locally.
further my 'failed access' was something i wasnt expecting to work.
regadrless, my underlying issue is router access when the internet goes down.
again my apologies, i appreciate your understanding
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 2093 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
