Reply
nighthawk app
ebsharb
nighthawk app
I used the nighthawk app and pushed wrong button and now my devices wil not connect, but only my laptop. How can I change the access back to my household devices? Thank you
Model: R6900v2|Nighthawk AC1900 Smart WiFi Router
Message 1 of 4
IrvSp
Master
Re: nighthawk app
What button? What did it do?
What errors are you getting on the other devices?
Message 2 of 4
ebsharb
Re: nighthawk app
Not sure which button, but I looked at a youtub video and it may have been in the device list or WiFi settings or Remote management area. Thank you for any help, so I can log in on my computer to the router and fix the issue.
Message 3 of 4
IrvSp
Master
Re: nighthawk app
So far not much to go on what you did do?
You probably need to RESET your Router. There IS a RESET button on the back that is in a small 'pinhole'. A pen or paperclip can be used to depress it and hold it in until the router resets. See https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router. You should then be able to access it and set it up again.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 317 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
