× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
nighthawk m5, solution for 24/7 remote operation, reset after network down?
wake-watch
Follower
I have a nighthawk m5 mobile router using a public IP address with telstra. It is at a remote site. Every few days the M% looses its connection with the network ( the signal bars are still good, and to reset it I have to drive 200km. Will an auto power off-on reset to avoid a long trip?
Message 1 of 2
Guru
Re: nighthawk m5, solution for 24/7 remote operation, reset after network down?
Have a scheduled power cycle with a external power switch may help.
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 761 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
