- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
nighthawk x8 ac5300 Not Boot
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hy,
yestarday my WiFi had a problem to boot. The poweron led stuck in amber light. I surfed over the forum, see that maybe there are problem on the firmware and I tried to reload firmware but did not success.
Before to throw away the router, there is a way to get it working again?
thanks
Cesare
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: nighthawk x8 ac5300 Not Boot
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
