Discussion stats
  • 1 reply
  • 51 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
nighthawk
CAN THESE UNITS BE USED OVERSEAS?
Message 1 of 2
Highlighted
Guru
Re: nighthawk
most devices can be used elsewhere. there's certain changes/modifications needed.
1. power. not all places use same power requirements. potentially a different power supply is needed.
2. firmware. each region has its own broadcast restrictions. So each region will have a different settings for that region. Some require a different firmware specific to that region.
3. Patience. sometimes changing the region requires some computer work/skills. see this thread for example. https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R8500-how-to-unlock-wifi-region/td-p/1495922
If you're not comfortable doing stuff like this, buy a router specific to your region.
so its not as simple as just taking a router elsewhere and plugging it in.
CAX80->GS716v2->RBR50->RBS50-RBS40V-RBS50Y
Message 2 of 2
