- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
no confirm button to initiate firmware upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
In an effort to update the firmware (1.0.0.60), which I have done on this computer before using Safari, I cannot see a button to allow me to confirm that I would like to do the update to version 1.0.0.94. Please see the screenshot.
I have also tried this on Google Chrome, as well as Firefox, but the button to confirm the update does not appeasr in any of them. Further to that, I have a differnet Netgear router at home and was able to update the firmware last week without any issue.
When I locate the firmware update file to download is manually, it shows what appears to be a higher version (1.0.0.104) than the one that shows when trying to use the update assistant (1.0.0.94).
Why is the confirm button not showing to allow the update to be done in the assistant?
If I have to do this manually, is the higher version (1.0.0.104) suitable considering that it is not the one offered when using the assistant?
Regards.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
> in the assistant?
Fine quality firmware development and testing?
> assistant?
If you're in doubt, then look for "View Previous Versions" under the
latest available version on that page.
Complaints abound about failure to suggest multiple newer versions on
the R7000. One example:
https://community.netgear.com/t5/x/x/m-p/2069376#M186506
Similar problems on other models would not amaze me.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
> in the assistant?
> assistant?
