Orbi WiFi 7 RBE973
Reply
no lan ports working
Petermary
Follower
no lan ports working on nighthawk x65   ac3000  any suggestions--help?
Message 1 of 2
Accepted Solutions
antinode
Guru
Re: no lan ports working
> no lan ports working [...]
   Determined how, exactly?  LED indicators?  But wireless is?
   "not working" is not a useful problem description.  It does not say
what you did.  It does not say what happened when you did it.  As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
> [...] on nighthawk x65 ac3000
   None of that is a model number.  Look at the product label.
   Firmware version?
   Unplug the cables from the LAN Ethernet ports.  Use a known-good
Ethernet cable to connect any two of those LAN Ethernet ports.  Do the
port-status LED indicators indicate a good physical link?
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual.  Look for "LED" and
"Troubleshoot".
Message 2 of 2
All Replies
antinode
Guru
interpretations.
   Firmware version?
"Troubleshoot".
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1160 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
