Reply
not connected to router's wifi network
Retired_Member
Not applicable
Nighthawk router is connected to ISP's router. Internet connection light on the router is lit up. The router's network does not show up in the list of wifi networks on my computer.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 5
yddtime
Luminary
Re: not connected to router's wifi network
Which ports are you using?
Which router?
Which router? How did you configure the Wifi?
R7000 is in the recycle bin
Message 2 of 5
IrvSp
Master
There is so much info missing here I don't know where to start?
First, WHY are you using 2 routers?
Do you have a WIRED connection?
How did you setup the NG router?
Which leads to did you ENABLE the SSID's and the BROADCAST of the SSID?
Can you CONNECT to the SSID if you use 'other' or 'hidden' options on the devices to connect?
If on Windows, did you run a 'WIFI SCANNER' like Acrylic and does it see the SSID?
What SSID band are you connected to (2.4 or 5Ghz)?
What are the colors of the LED's on the router top? Is the WIFI on one?
What CHANNELS are your SSID's on?
Message 3 of 5
Retired_Member
Not applicable
Problem has been resolved.
Message 4 of 5
IrvSp
Master
Mind telling us what you did?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 420 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
