Reply
opening poort 2001
Wattsp
Follower
opening poort 2001
i have arris cable mode i got from spectrum.so turned off all wifi anbridged it to my NHR7900 and use it exclusively.i have DMP alarm system that i need to acess remotly and i need to open port 2001.ive done the port forwarding but still cant see port open. i shouldnt have to do anything to the spectrum unit i wouldnt think
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 2
antinode
Guru
Re: opening poort 2001
   So, you have some (unspecified) model of Arris cable modem+router,
and you did what, exactly, with it?  What, exactly, does "bridged it"
mean to you?  Is an "NHR7900" anything like an "R7900"?  What, exactly,
is the model number on the label on the router?
   What is the WAN/Internet address of the "NHR7900"?  Perhaps: ADVANCED
> ADVANCED Home : Internet Port : Internet IP Address.
> [...] i need to open port 2001.ive done the port forwarding [...]
   With my weak psychic powers, I can't see your port-forwarding rule.
Copy+paste is your friend.  Presumably, this (undisclosed)
port-forwarding rule contains the IP address of the (unspecified) "DMP
alarm system".   What did you do to ensure that the alarm system will
always be found at that address?
> [...] still cant see port open.
   When you did what, exactly?  As usual, showing actual actions with
their actual results (error messages, LED indicators, ...) can be more
helpful than vague descriptions or interpretations.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 131 views
  • 0 kudos
  • 2 in conversation
Announcements
