Reply
orange or amber blinking lan ports
oiljars
Follower
1 lan port to mac is whte
1 lan port to direct tv blinks an orange or amber color
1 lan port to Ooma VOIP blinks an orange or amber color
ports 4 - 6 no LED / not in use
why are ports 2 and 3 blinking an orange or amber color?
thanks
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 2
antinode
Guru
Re: orange or amber blinking lan ports
 > why are ports 2 and 3 blinking an orange or amber color?
   Sometimes, reading the manual can be helpful.  For example, the "User
Manual" for my R7000 (page 11) says:
LED         Description
Ethernet    The LED color indicates the speed: white for Gigabit Ethernet
ports 1-4   connections and amber for 100 Mbps or 10 Mbps Ethernet
            connections.
            o Solid. A powered-on device is connected to the Ethernet port.
            o Blinking. The port is sending or receiving traffic.
            o Off. No device is connected to this Ethernet port.
   Perhaps the manual for your R9000 offers corresponding information.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 6368 views
  • 0 kudos
  • 2 in conversation
Announcements
