- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
orbi RBR50 No SSID broadcast
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi RBR50 stopped broadcasting SSID, i tried resetting the router, but didn't help. Please help. I can't even login to get Firmware version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: orbi RBR50 No SSID broadcast
Whats the power light doing? (color, solid)
What is the led's at the top doing? (color, solid, blinking, etc)
Are you able to hardwire in a pc/laptop to the router and access it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solid Green
Blinking White ring
Yes, Modem is working and able to directly connect using my laptop
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the led at the top is blinking white, it means its in factory default mode and needs to be setup.
What do the LEDs on my Orbi router and satellite mean? | Answer | NETGEAR Support
Try hardwiring a pc/laptop into the orbi router and going through setup again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried directly connecting to the router using ethernet cable but couldn't connect. So, what is the best way to hard reset or apply the latest firmware? Can I upgrade firmeware using USB?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@DevB wrote:
I tried directly connecting to the router using ethernet cable but couldn't connect.---what error were you getting? how did you try to connect? using its ip address? using routerlogin . com, how did you attempt it? So, what is the best way to hard reset---sounds like you're already reset. its as simple as pushing and holding reset for 7-15 seconds while powered on. or apply the latest firmware?----If you're logged in, thats the easiest way. If you can't get in, then it'd be using tftp or nmrpflash. Can I upgrade firmeware using USB?---No, you can't upgrade over usb.
