- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
pandora not loading songs, just buffering r7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
current firmware V1.0.9.10_1.2.21
I am unable to get pandora to play on any device that is connected to the router. Wired or wireless no device will play, only get buffering.
Spotify and youtube work correctly but nothing on pandora.
Neither the website on a windows pc of trhe app on phones work.
This have been going on for a few weeks.
Anybody else have this problem or any ideas on a solution?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi moosehead,
Did it happen after the update?
Reset the router to factory default and reconfigure it. Check if the same problem.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi moosehead,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: pandora not loading songs, just buffering r7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi moosehead,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
