Reply
port forward
compwarez
Follower
port forward
what is the stock firmware version number? i just to port forward r7000p router. it is still not working.
pls help me.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
antinode
Guru
Re: port forward
> what is the stock firmware version number? [...]
   There is no "the stock firmware version number".  What's your
firmware version number?  To what is your R7000P connected?
   Visit http://netgear.com/support , put in your model number, and look
for Downloads.  (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".)  Find the kit(s).
Download the kit(s) you want.  Read the "Release Notes" file for
instructions.
> [...] i just to port forward r7000p router. [...]
   Huh?
> [...] it is still not working.
   Perhaps you did something wrong.  Or, perhaps there's a problem with
your router.  Sadly, with my weak psychic powers, "not working" is not a
useful problem description.  It does not say what you did.  It does not
say what happened when you did it.  As usual, showing actual actions
(commands) with their actual results (error messages, LED indicators,
...) can be more helpful than vague descriptions or interpretations.
      https://community.netgear.com/t5/x/x/m-p/1859106
> pls help me.
   You first?  Any useful information at all might be better than none.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 167 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
