- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
problems after setting up AC1900 EX7000 again for new router
- Mark as New
- Bookmark
- Subscribe
- Permalink
My router-modem was replaced. I set up the Nighthawk extender again, and the process said it was complete and successful. All 3 lights are solid green.
2 problems:
1) The completion screen said it was successful but said that the 2.4GHz extended network was not connected. The 5GHz network showed as being ok.
2) When I try to connect my iPhone or iPad to wifi, only the base router shows up.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
It had the latest firmware because I did the update before doing anything else.
It's solved.
1. The Not Connected was on the status screen and just meant nothing was connected to it.
2. My iPad and iPhone couldn't see anything other than the basic router ssid because the use same name box was checked. I changed that and now can see what's being chosen for wifi on devices.
Thanks
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: problems after setting up AC1900 EX7000 again for new router
1. What firmware is on the EX7000?
2. The ex7000 was updated to be a mesh device. meaning if you have new enough firmware and set it up using WPS (or during setup), it uses the same ssid as the primary router.
3. When you say 2.4ghz isn't connected, is that through the status page or its just not showing as broadcasting? A bit more details helps here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's solved.
Thanks
